Old 13th October 2010, 08:49 PM
Locky Locky is offline
Default Steel quantity
Im looking to price up my steel, just wondering how much i will need for my build. I dont want to buy 10 meters too much of steel as i just wont use it.
i priced up 20mts of 25x25x16swg erw and it was £30+ vat. is this an average price? the book doesnt show a quantity list.
Thanks.
If it has breasts or wheels it will give you problems.
Planning Stage
Old 13th October 2010, 08:54 PM
depends if you are building the chassis to book spec or to accept the Saturn GRP rear tub, but if its the latter you will need approx 37 mtrs of 25mm box & approx 18mtrs of 19mm ( 20mm is fine ), most builders pay about £110 plus delivery for the above .
You will end up with a little left over of each size, but it comes in handy for making "dummy shocks" etc.
hope this helps
Old 13th October 2010, 09:25 PM
Il order the extra in case i take the saturn route. Thanks for the help Andy
Planning Stage
Old 13th October 2010, 09:29 PM
No probs, happy to help
Most steel stockists supply the steel in either 6mtr or 7mtr lengths so it may appear that you over order but I assure you, the extra comes in handy ( ) for other bits or for having a few practise welds etc.
best wishes for your build
Old 13th October 2010, 09:32 PM
I used up 42 m of 25x25 (a couple of offcuts left, just one of them longer than 50 cm, great as a wrench extension) and 14 m. of 20x20.
Old 13th October 2010, 09:47 PM
Locky....If you are going the Ali tub route, don,t forget the round tube needed
I must admit when I order steel for a chassis kit I order 6x7mtrs of 25mm & 3x7 of 19mm, but I always have steel left over, also the kits go with spare steel so I tend to use what I need when I need it
Old 13th October 2010, 09:48 PM
mark mark is offline
You can guarantee you will cock up a few times too so a little extra is always nice
We have all been there measure twice cut once realise its wrong measure again cut again etc etc!
Especially when you have been cutting compound mitres!
Old 13th October 2010, 10:18 PM
Wont be using ali tube i dont think.
As for items RP1 and 2 I am going to use a some steel conduit i can get from work for free and alraedy galvanised, plus i have a tube bender up to 25mm tube for work which will come in handy.
Planning Stage
Old 14th October 2010, 07:49 PM
Galvanised pipe is nasty stuff to weld and poisonous too with the zinc coating.
Old 14th October 2010, 07:53 PM
Its fine if you grind it off the surrounding area first as its only a thin coating
Flyerncle is quite right though zinc poisoning or galv flu as its known by welders/fabricators is more serious than people give credit for.
