Old 29th November 2011, 11:27 AM
MarkB MarkB is offline
[quote=Bonzo;68393]
Originally Posted by MarkB View Post
The Sierra based Roadster handles like a shopping trolley and understeers for a past time but that is my opinion and no doubt will be frowned upon[/QUOTE
That is only my personal opinion of that post
What a pity that you never took the time to build one & by your own admission, wouldn't even drive a 7 type car
Hey ho, you have to get your kicks somewhere & I guess this forum is as good a place as anywhere
There are plenty of 7's that handle, I have built a few but had no interest, time or space to build a Roadster. Sooner make something different....as for being a Troll well that made me laugh........
Old 29th November 2011, 03:57 PM
MikeB MikeB is offline
can't wait to get mine built and on the track to have a look at this understeer problem.
From my understanding it will be the high g corners where theres a lot of body roll. Aparantly there isn't enough camber gain on the front suspension, i.e the camber angle can't keep up with the body roll angle. Thus causing the outside front wheel to camber out under heavy cornering. Thus causing a bit of understeer. The front shock angle is also quite low so effectively you loose stiffness the more wheel travel (or roll) angle you see.
Three things I'll be playing with to solve this (or minimise this)
1. Static camber angles, probably come up with a track and road setting.
2. Limit the body roll with some antiroll bars (or stiffer strings)
3. Weight distribution etc to give a more neutral oversteer charactersitic.
Other than Ash I'm not sure who else has actually experienced the understeer and this could just be down to the basic geo setup.
As said on the road it isn't going to be a big problem, on track you might feel like you not quite getting the most from the tyres. No biggy.
In my opinion a wider chassis would look naff
Old 29th November 2011, 07:55 PM
From experience of the Roadster I put together in conjunction with Saturn the total opposite is true and has a lot of oversteer when corner weighted and set up to suit the driver,it is wearing R1R Toyo,s at about 26 psi or there abouts and standard Protech,s and shorter springs.
Old 30th November 2011, 09:33 AM
Yes you're right Paul, the roadster can be set up and corner weighted to suit the drivers preference. For the track my setup is the opposite with some understeer that i can balance out with my right foot and get some really nice 4 wheel drifts coming out of the corner, the front can really turn in while coming off the brakes into a corner. Really is good fun - wish it was spring / summer again.....
AndyH
Old 30th November 2011, 09:43 AM
It is just wish i had my car finished.
Old 1st December 2011, 03:14 PM
davidimurray's Avatar
AndyH
Spud - any chance you would be kind enough to share your setup with us ????
Old 1st December 2011, 07:06 PM
mark mark is offline
I personally find with my car it would be hard to quantify the setup as it currently is
I did use some inital numbers from locost builders but after driving it i altered things here and there to make it behave how i wanted
Spud has obviously played with these cars more than me so maybe he has some exact settings to start with, but with so many variables such as engine weight, power output, springs/dampers, wheel and tyre choices make everyones car different and behave differently
Im sure you will soon get it feeling "right" once you get it on the road and have a play
Old 2nd December 2011, 10:04 AM
Mark is right there, a lot of it is just by feel and tweaking it to your own preference and will vary between cars. I've found that a good starting point is:
Front:
Toe in 2deg, camber 3deg (will vary on driving style), castor so that it just starts to self centre
Rear:
Toe in - none, camber 1/2 deg
Corner weighting the car is important with the driver in the car, adjust the springs to get the car even all round then you can balance the car between the front and rear. Adjust the ride height, 100mm front / 125mm rear, to as low as you dare for speed bumps and turn up the bump / rebound to as stiff as our crappy roads will allow. If you go on a track day you can drop the car right down and damper setting as stiff as they go and it will make quite a difference.
Hope that helps.....AndyH
Old 2nd December 2011, 10:15 PM
Spud you are a star (and my wife says you're a darling ) !!!
Thanks for the setup info - duly recorded and noted!
Old 3rd December 2011, 10:55 AM
Well David i dont know what to say, i'm redder than the post box red of the body we are gelling today....... Hope my misses doesn't log on today.
Have a good weekend......AndyH
