Old 10th August 2012, 12:20 AM
mgglep's Avatar
mgglep mgglep is offline
Default Carbs
Hi all I was going to run the standard sierra pinto setup until after iva but a have got very little room under the bonnet for an air filter I wondered how others got round this I would like motorbike carbs can these be ran without engine management
Thanks for any help
My Build pics
Old 10th August 2012, 01:50 AM
I think it's well settled -- if you're running a standard downdraft carburettor, you have a hole in the bonnet for a chrome or foam filter. A way to avoid it is a set of sidedrafts, or bike carbs.
Old 10th August 2012, 12:18 PM
MikeB MikeB is offline
i think you can use the same ignition set up you have for bike carbs but most will use megajolt or (I'm waiting for Nodiz from m-tech to come out next month).
Old 10th August 2012, 12:49 PM
jps jps is offline
I'm planning to do motorbike carbs on a pinto too - potentially permanently. How do you go about getting a manifold made to suit the carbs?
Old 10th August 2012, 11:06 PM
mgglep's Avatar
I have seen the manifold kits on eBay I think the kit is about 60 and the kit all welded up is about 130
My Build pics
Old 11th August 2012, 02:23 AM
I believe "fastdan" on Locostbuilders does all that sort of thing. Think he has a website as well.
Old 11th August 2012, 10:14 AM
TSM Locost's Avatar
Dan's website www.danstengineering.co.uk/
Be Lucky, Mike.
Old 11th August 2012, 10:37 AM
I held the carbs in front of the engine, in around the right place I wanted them (bowls flat, good intake lengths). Propped them in place and took some measurements. Then I made a wooden jig, to which I fitted my manifold plate, I cut some tubes to suit. Took a whole day, but does the job.
Old 11th August 2012, 11:07 AM
Stuff like this needs a top tip sticky. Another case of a picture says a thousand words
Old 11th August 2012, 02:37 PM
Added to the FAQ, link below vvv
