Old 26th April 2011, 09:35 PM
Ok Andy two more questions, can the original Mazda 14" wheels be used with the suspension and steering set up, and can you use the Mazda steering column with the escort rack?
Old 27th April 2011, 10:37 AM
Yes, the roadster uses the original mx5 uprights front and rear so the original 14" wheels can be used. Also the original column can be used but needs a few mods with the rack extending and and a new mounting bearing used along with the escort rack.
Andrew
Old 27th April 2011, 11:25 AM
cornishmaid cornishmaid is offline
I'm eager and curious to see when the Saturn Mx5 will be ready as would like to see if we came to the same conclusions with certain aspects of the suspension.
Built February 2009 using Mx5 components.
Old 27th April 2011, 01:38 PM
Andrew
Ahh thanks Andrew. So the escort rack is used and extended in the normal way but the steering column need modifying and a bearing mount used somewhere in it's length.
Old 27th April 2011, 07:48 PM
We found it to be rather more involved than going down the Sierra route, wasn't as simple as it first looked. But saying that it was well worth all the hard work.
Old 28th April 2011, 09:06 AM
We'll have to discuss our conclusions over a few pints at Stoneleigh CM, i assume you will be there after your query regarding suppliers showing this year.
Regards.....Andrew
Old 28th April 2011, 03:10 PM
Regards.....Andrew
Should be an informative weekend all round.
Old 17th May 2011, 07:38 PM
Apologies to saturn for not meeting up at the show, we never actually managed to get there due to an illness in the family.
How is the Mx5 car coming along as I can't see recent updates?
CM
Old 18th May 2011, 09:28 AM
MarkB MarkB is offline
CM
Argh that explains why I couldn't find you then, hope all is well now?
Old 1st July 2011, 08:21 PM
Dave F's Avatar
Dave F Dave F is offline
Slightly off topic but I have decided on the MX-Donor but for IVA & Registering sake do I need a UK spec. I don't want the logbook to say import or even turning up for the IVA and they saying "have to be a Q mate" all because I used a Eunos.
